Tire pressure indicator on dash
Cajun_Tiger_Hummer
Lafayette, La
Tire pressure indicator light came on this morning. I checked the tire pressure on all four tires even spare tire, everything is good. Put a little extra air in for good measure. Light still won't go off. Bad TPMS sensor maybe? Anyone run into this issue?
benlaud87
Maryland
Do a tpms relearn, the instructions are in the user guide/manual. The spare isn't monitored, only the 4 tires on the ground. After that you will have to drive it for a bit before the light goes off. If that doesn't work then you may have a bad sensor
Cajun_Tiger_Hummer
Lafayette, La
I get them rotated every couple months. Service TPMS sensor isn't on, Good year always resets it when i have them rotated. It's just my low pressure indicator came on, but my tires aren't low.
kilroy
Owosso MI
Sounds like a bad sensor, they're powered by a non-replaceable watch battery. Hold onto your shorts when you see the price though. List price is about 90.00
Peep
Belize
Duh!
i forgot I had a bad sender once, and it ordered a new one to fix the error. The sending unit is attached to the valve stem
3rdH3
Blacksburg, VA
I hope that fixes it. If it is a bad sensor you normally get the TPMS error on your DIC and not just the low tire icon. I guess one could have been reading low. Good Luck
kilroy
Owosso MI
$80.00, Really? Hate to say it but any reputable tire shop would've charged a mount/remount and balance fee, installed the stem and relearned it for free so long as you bought it there. Must work things different in your area.
Cajun_Tiger_Hummer
Lafayette, La
Guess so, going rate is $80 an hr in my area and cost of the part ($30 something). After tax it was $123.00. These guys have been doing all my tire installation and up keep for many years. I wouldn't bring it anywhere else even if i could find a cheaper deal. It's not like i was breaking the bank shelling out a clam and a qtr. anyway. :)
