Tire thread
Chris, just get a set of H3x wheels with 265's to swap-on for when you're not out wheeling.
Sent using Tapacrack
Scarsman
Monroe, WA
Have you thought of the Cooper Discoverer STT? I love those tires, and they seem to pull through anything!
I'll second that. I love my STTs.
not really...are they a heavy tire? I am trying to keep the tire light, thats the main reason I am staying away from the Toyo MT's
If you look at the list of weights you posted, the Toyos are clearly heavier, but the STTs and all the other ones are within a couple pounds of each other.
I have had my STTs in pretty much every condition there is, and have not found them lacking in any. They are soft and flexible when aired down, yet very tough. I have run the sidewalls through/over things where I was certain I would be changing the tire after, but they just ate it up without a mark.
I just rotated the other day, and have 11,000 miles on them. I checked the tread depth and did the math, and on paper, if I ran them down to 5/32", they are on course for just over 50,000 miles. While I doubt they will actually reach that, it looks promising!
seventwozero
Fargo
Who has 2 sets of tires? Street and offroad? I have money saved up and am finally going to pull the trigger. I cant decide if I should go with 2 new duratracs with 2 new unused spares I have and then 4 MT/Rs for offroad use. I am driving over 1000 miles a month and would hate to see the MT/Rs be done in less then 2 years.
I did on my truck before, it was actually summer and winter, same idea though. After two seasons of messing around I gave up and ran the winter tires (BGF AT/ko) year around. The thought has never crossed my mind with my 2 though, considering the weight of the 37" Toyo I only want to mess around with them if I absolutely have to!
Does anyone have experience with the Interco Irok's? I've been thinking about a set when the Toyo's need to be replaced. The 37" flavor weights in quite a bit less than the Toyo 37", @ 69lbs, the Irok 39.5" @ 85lbs, the Toyo 37" @ 92.6lbs!!!... now I just need to figure out how to squeeze those guys in the wheel wells without a 6" lift! :horns:
MaxPF
AGNTSA
The dark side of the globe
I have found that after 2 years the rubber compound has hardened so much that they don't work well off road, regardless of how much tread is still on them. So, I'd say get the MTRs and plan on replacing them every 2-3 years.
08SolarFlareH3
Super Swampers
Finger Lakes, NY
1" or 2" body lift. Don't remembers whos this was but IIRC he was from MI.
39.5" Iroks....there are also pictures of it floating around with 41" Iroks but from what I understood there was a lot of trimming involved with the 41's.
Also, the weights you were quoting are for the bias ply Iroks. The radial 37s are 81lbs and the 39.5s are 99lbs.
seventwozero
Fargo
I am in love with this SUT!
Thank you for correcting me on the weights, even 10lbs lighter per tire is an improvement though. From what I understand, 10lbs of rotational mass is like 100lbs of cargo weight? (roughly of course)
Edit: After some quick googling it looks like 10lbs of rotational mass (on tires anyway) is more like 20lbs of cargo (roughly 2x).
TXH3T
Prescott AZ
Hmm has anyone had much experience with the Hankook dynapro m/ts? Ive been running 35" BFG TA/KOs and just bought a set of the hankooks. I heard great things in reviews but I guess we will see. Cant beat the price though got 4 new 35" tires from discount tire with warranty for 1100. Now I just gotta wait to get my truck back from the shop to put them on :sigh:
Scarsman
Monroe, WA
I thought about those when I got my ties, but nobody had them. They sure do have good reviews!
MaxPF
AGNTSA
Where are the Hankooks made?
08SolarFlareH3
Super Swampers
Finger Lakes, NY
Found a picture of a Dynapro M/T on eBay and the first two digits of the DOT number were T7. So they are (or atleast some sizes are) made in Korea.
T7
HANKOOK TIRE MFG. CO., LTD.DAEJEON
PLANT
DAEDEOK-GU
DAEJEON
KOREA
*edit,
Just found another DOT plant code on another size tire, BJ. So it appears that some are made in China also.
BJJIANGSU HANTA TIRE RADIAL PLANTHUAIYINJIANGSUCHINA
I was checking on tires last week to maybe get another set of STT and my dealer tried to order them from the distributor and they said they are no longer made?
Other than seeing them online in stock has anyone else run into this?
Might be time for me to look into more of an AT with open tread.
I did some searching today and may drop back to this.
Discoverer S/T 315/75 R16
I ran across some info that shows the Cepek FCII is a cooper tire on that armor tech carcass and that MasterCraft Courser C/T is as well. I may check into those.
TXH3T
Prescott AZ
Korea I believe. They talk about being in the US for a long time etc on their website but they are based from Korea. Heres one of my tires
Scarsman
Monroe, WA
Well that's not cool! Unless maybe they're coming out with something better!
SC_Hummer_Guy
Mr. Sexy Sugar Britches
North Charleston, SC; Angel Fire, NM
I just checked to see if I could order some here from South Carolina due to I'm getting new tires in like a month. They are still available here from Discount Tire. Not sure the reason you couldn't get them, but they aren't off the market from my shop. Best of luck tracking some down!
Portager
Silverado
I went to the Cooper Tires web site and there was no indication that the Discoverer STT was discontinued. I'd check again, possible with another distributor, and make sure somebody didn't get a digit wrong when they searched.
Flash
Michigan
Pretty sure that is Rick's truck. No longer has it. At one time he ran 42's. Lots of custom fabrications and plenty of breakage.
08SolarFlareH3
Super Swampers
Finger Lakes, NY
The Cooper Discoverer STT is still being produced, our vendor shows 14 in stock (which is about the normal stock level for a tire of that demand). The Cooper Discoverer S/T is a great hybrid tire. We use them on a lot of fleet and large breed veterinarian trucks.
The only distributor here is like 60 miles away. Not sure what the deal was with that. I will check again.
I sort of like the S/T and there was one other more aggressive I think, before going to the STT, but it did not come in 315.
It so dry around here I forgot what mud was!!
ST Maxx
ST Maxx, it still uses Armor-Tek3 Carcass Construction
