TRACTION, FAILED, SERVICE , STAB SYS. Now What???? 09 H3
650Hawk
Weird thing is... Why would the air intake data screw with the traction control system????
From what I understand, anything that affects the engine performance, will automatically shut down the Traction Control, as well as Stabilitrac.
DERP
Ontario Canada
I’m getting the same TRACTION FAILED, SERVICE STAB SYS . I recall someone telling me my brake lights weren’t working a while back. Ut then they started working again. I bet it’s the brake pedal switch working intermittently. I will check tomorrow morning.
Vaderdad
Tampa, FL
What does your Hummer do while this Stab Sys off code was active? I have this same code and my H3 happens to be in limp mode. Front or rear wheel makes a skirttttt noise when I drive it forward into a turn.
lfootmatt
AZ
I didn’t read the whole thread, but I’ve had this occur a couple of times. It was a bad battery every time. New batt and full charge solved it. With good battery terminals of course!
