trans filter #?
Anyone have the transmission filter part #?
ACDelco 24208576.... Is this the right one? Comes with filter and gasket.
Clarke
SE PA
Is there a way to change the filter without making a total mess of ATF spillage? Any tricks?
according to 4speedfunk, leave one bolt in at one of the corners and the fluid will pour out at the opposite corner. thats really all you can do. use a big pan to catch as much as you can and probably gonna wanna lay down some rags ahead of time. you could always add the pan with a drain plug once you have the original off. that way its easier next time.
Link? I don't think there's an aftermarket solution here for our pan. If you want to do a drain plug you need to fabricate it into the existing H3 specific pan.
Best4x4
Vidor, TX
I loosen all the bolts but two on the pan, then use a small kid pool under the H3 to catch all the fluid. A hose down the dipstick tube would work, but I just use the kid pool, and do everything from under the H3.
I used whatever Auto Zone sells for the gasket/filter and I used Castrol Dex VI compatible fluid.
rsc
Tulsa
I have to go by the shop monday, I'll see if the one Amazon said was a fit actually does fit or not. Either way, It's getting a drain plug on it.
I think the Dorman is gonna be iffy. I think it'll fit the transmission but it's a question if it'll clear the front prop shaft.
rsc
Tulsa
It doesn't fit, despite Amazon's big green check mark and statement that it does. It looks exactly as pictured on the website, even better in person actually. Looks like I'll be drilling a hole and welding on a nut.
Well hell... Lol. I won't even unbox mine when it shows up. I'll just send it back. Gotta find a shop to drill and weld in a bung for me.
Told ya so [emoji12]
Sent from my SM-N910V using Tapatalk
did the pan not even fit on the transmission or did it just not have clearance once back in the vehicle? O'Reillys website also says that pan is a direct fit for my 06... Dorman makes a universal trans pan drain plug that can be added by drilling a 1/2" hole in the pan. Im gonna pick one up tomorrow. I've seen they work pretty good. One guy installed one with a little rtv for extra leak protection and hasn't had a leak in 3+ years. It's either that or call a local transmission shop to see if they can weld something on. I'll probably call tomorrow and see what they recommend. I'm still waiting on fluid and the new cooler and everything else to show up.
rsc
Tulsa
It was not back together yet, just based on looking at it in my hands. It might "fit" when sitting there stopped but not well enough to trust when the vehicle gets rocking around.
Since the IFS front diff is fixed, and the t-case is fixed, there shouldn't be hardly any movement of the front prop shaft?? It's Nike like the rear that's moving up and down with the axle. How come it wouldn't work while bouncing the truck around?
rsc
Tulsa
I'm thinking about chassis flex. With our boxed frames it may not be much movement. I just think about sliders and how stout they are (like the Rocky Roads) and have seen pictures of them bend, I wouldn't doubt that there is just enough twist in the chassis to hit. Its all just speculation for now, I think the shop really wanted to see if it would fit anyway.
