Transmission Cooler W/ Fan
cory9oh4
Florida
So I've spent a few days researching transmission coolers and reading through the posts here on the forum about the installs and what sizes to get. I'd like to get one with a fan if it can be found for a decent price. Florida summers get hella hot so the more cooling I can get the better. I've got a few questions about the fan.
1) Where would I go about wiring the fan up for power? Would it be possible to use something like: http://www.glowshiftdirect.com/expandable-circuit-and-4-amp-fuse.aspx
2) Does anyone know of a good cooler w/ fan?
3) Does the fan run all of the time or at certain temperatures?
Depending on what you get, a trans cooler with fan will have its own built in sender unit that tells the fan when to go on/off. Once trans temps are above a specific temp the fan kicks in. The power will need to be taken directly from the battery since there is no oem provision for it.
