Transmission Gear while in 4-Low
Vdawg1115
Oakland, CA
I was wondering if anyone ever puts the transmission in 3 or 2 while in 4-Low. Recently at Hollister Hills I got to try out putting the tranny in 1 to crawl down steep hills and crawl it did! I did not expect such a slow crawl down hills but it's a good thing. Otherwise I'd always have it in D while in 4-Low. Is there ever a time or place to have the tranny in 3 or 2?
Vdawg1115
Oakland, CA
When are you using 2 and 3 though? Just wondering. So far I have found that I can do everything fine in D, except the steepest downhills where I use 1
CaseyS
Louisiana
One of these days I will get around to hooking up my tap to shift feature on my transmission controller. Should be able to select the gear I want and hold it.
I use 2-3 where I hit a higher speed section of the trail but still want 4lo. 1 is great for hill decent
awalsh
New Jersey
Just wondering.. 4 low is best for downhill correct? Never had anything positive come out of trying to climb with 4 low, only 4 high. But that being said I have a base and not adventure so I don't have locked diffs
cbetts
NERD!!!
Rancho Palos Verdes, CA
Depends on the climb. If sandy, you might want keep the wheels spinning. If rack crawling, low and slow is the best.
cbetts
NERD!!!
Cool, this is all good stuff, just want make sure that whatever I am doing, I won't hurt my T-Case or anything
Typically, wheelspin can be bad. If the wheel has a lot lot of freespin and suddenly grips, all that power will transfer down the line. Typically it will take out either tie rods or halfshafts. Of all the damage I have seen on trails, the number one cause of carnage is too much throttle.
Cowboy
Alameda
When you can use engine only down steep hills is best. Sometimes, when going downhill, if you tap the brakes it will cause one wheel to lock up and slide. When it hooks back up, it puts undue stress on running gear. Which will snap stuff
Rock crawling; power up a rock , then controlling the break over so rock doesn't slam slider.
Snow/ sand; controlling wheel hop and again stressing drivetrain.
Can't make it through the day? Back up, and get a run at it!
I only manually shift the auto while in 4 low. I never use "D". Most of the time in "1", sometimes in "2".
Vdawg1115
Oakland, CA
Well, what do do yall think is the best tranny gear to be in while on a rocky incline? I have been doing so only in "D". Just wondering if i would be "crawling" better if I was in 3 or 2.
rsc
Tulsa
Just one more reason I dislike automatic gearboxes, drivers only learn how to put it in Drive and go. I know some of this may sound overly basic, but the decision of when to take it out of D is up to you. D does all the thinking for you while cruising around, but sometimes you just need more control than that over how long the computer holds the gear you're in or when to shift- like when going down the highway in that long, downhill corner...that would not be the time to be in D and finding the computer upshifting. You want to use 1, 2, and 3 for those times you need to control engine or vehicle speed more closely. In 1, 2 or 3, you use the engine braking more effectively. You may be coming up over a rock (or curb) and want to slow going over the top of the high point then go again, maybe 1 gives you the control to hold the transmission in gear so you aren't coming in and out of gear right when you need to be in the power again without rolling backwards. Going up isn't as demanding on gear selection as going down, the auto will upshift and downshift as necessary to the highest gear selected automatically whether 1st, 2nd, 3rd or D (up to 4th/overdrive). Going downhill it is the reverse, staying in D lets the car "freewheel" down hills where 1, 2 and 3 limit the upshift to the gear chosen and will hold the gear more before letting the torque converter freewheel. Putting the transfer case in 4Lo engages a different set of shift parameters and the transmission will hold gears longer, upshift later and have a firmer, more aggressive shift feel at the same time. I guess after saying all that, 1,2, and 3 in an automatic are the closest you will get to full control over your vehicle like you would with a manual transmission. Use the lower gears to control engine and vehicle speeds, and shift up/down as needed for the conditions.
Following up on what RSC said, I tend to be in 1 on rocky terrain for absolute control, especially on inclines and descents. I use 2 for flat sections and rarely use 3. I use as much engine braking off road as I do regular brakes.
Vdawg1115
Oakland, CA
Thanks. This is all good info for me. I'll be sure to make the most out of it
