Transmission Pan bolts
D
Dennis
If you get a chance..take a look around the edges of your Tranny pan..do you see any wetness from fluid oozing?..if so, take a 13MM socket and box wrench under there and tighten all the bolts around the pan..about a 1/4 turn is all you should go.
Just another thing I found on mine that fixed the problem.
cbetts
NERD!!!
Rancho Palos Verdes, CA
If I see ATF leaking on mine, I have really big problems . . . :wink:
Thanks for posting that. There are a lot of little things that we need to start looking at on a regular basis once our trucks get close to the six digit mark. This is definitely one of them.
