Uwharrie Wheeling Trip - Sept. 21-23
telemike
Hummer Enthusiast
Greensboro, NC
What tire pressures do you usually run at URE? If I remember, with the loose rocks and type of soil, you don't really need to go down a lot?
ReconH3
Guardian Angel
Raleigh, NC
Depends if you have bead locks or not. Are the sidewall on your tire soft or hard. I have bead locks with very tough tires and run down to 7psi. It's not only for deformation but to stop tire bounce.
Yep, i was at 18 when this happened
I usually stick around 23-25 unless i have to go lower.
Looks like I'll be heading out with Perk. We're going to be truck-pooling in his H1. I just want to enjoy the trail ride and snap pictures this time around. :cheers:
telemike
Hummer Enthusiast
Greensboro, NC
I have 35's with the 2in lift no UCP is that going to get me around without tearing it up
You can do all the trails there with that setup. I used to all the trails years ago with an '89 4Runner, 2" lift and 33 x 12.50's. You need to watch for sharp rocks, and the off-camber on Daniel.
