woodwardsh3
- Oakland Co. Mi.
Ok hummer h3 I5 gurus please offer your tips or suggestions.
I have replaced my water pump 2 times now and it is leaking again. Not sure exactly where yet .
1st one was a bosh water pump it lasted about a year & 8000 miles when removed it did look like the shaft and seal were leaking.
2ed one was bought from 1aauto 10 year warranty ACdelco now it is leaking again.
When I removed the last one I used the gasket with no silicone on a clean surface and this time I used ARP thread sealant the white past
as the threaded holes go in to the water jacket and I torked them to speck from the forum. the belt tensioner is working there is no weird sound and
it is a very slow leak the one you smell but it's hard to find a drip. well now I can see a drip off the front of the motor on the driver side and it is wet on the front of the motor. I Have worked on cars an trucks an machinery for over 35 years so I should be able to handle this. Though I'm on a bit of medication for chronic back and neck pain from the 5 surgery Ive had over the last 25 years. So I do tend to take a lot longer to do the job and have to double check things as not to forget something.
Thanks for your help
