Welding the front
derian06
Red Rockett
Madison, AL
What would be the implications of doing this vs. buying a front locker. On 37's rancho lifted front and soa rear. Biggest concern is turning and high speeds.
kilroy
Owosso MI
Knew a guy that did this on the rear of a "68" Firebird years ago, not much of a problem so long as he was going in a straight line. Personally would NOT recommend it on the front of a full-time front end.
Ughhhh not an issue if it had locking hubs and 2wd mode, without those 2 critical things I would say you probably won't make it back to post the results
CaseyS
Louisiana
Even if you trailered you vehicle to the trail a welded front diff is a bad idea. On the road, and even worse idea.
Welded axles are not horrible. I know many guys that run them and they have their place. In most cases the vehicle will be very twitchy above 30 mph. Spools do not work well on a street vehicle (especially in the front). They add a lot of stress to the driveline and steering. In the case of the H3...its probably too much stress for the tinker-toy front axle.
Also the H3 has very sensitive electronic traction control systems that depend on unlimited slip (open diffs) to function properly. Any drag or connection between hubs will probably result in the computer fighting the mechanical locker....whether it be automatic, full-time, lunchbox, spool, or welded. This is why the Eaton selectables are the obvious choice. They have full slip when not engaged and they can be electronically defeated when Stabilitrac is active. Without this unique ability...GM could never offer lockers on a production vehicle.
