The rubber is all distorted and it a bit wet with transmission fluid. Is it possible for fluid to leak from this gasket deal or would the fluid have to be coming from a different location? Thx
It's just a plug. Any leak from that area means that something else is leaking onto it. Not desirable but probably not the end of the world either. Check the trans dipstick where it goes into the case for leaks.
