It is a loooong run, and resistance goes up with wire length. I probably would have gone 10ga but bigger is always better. Maybe look into shortening the run by taking the wire from the battery straight back to the left rear corner?
I looked into this again today. The fridge pulls 1.38 amp/hr at 12v with a 15a fuse. Running 15a over 15ft of wire requires a 10ga wire to stay within the 3% max voltage loss over the wire run. Looks like 10ga wire is needed. If copper prices were lower I would say use 8ga for future expansion, but 10 is good.
