Would a programmer on an i5 be worth the $?
H322
I have a buddy selling a Diablo Sport I-1000DCX in tune advanced programmer. It is unmarried and he is willing to sell it to me for a very reasonable price. My h3 has the i5 my question is would I see decent gains from a programmer? Would one even be worth the trouble I plan to order a aluminum rad here shortly also. Are these good mods for an i5 or should I just leave it as is. If I do install the programmer or there other things I will have to worry about or change? Thanks for the help in advance
Cyrus Avey
San Antonio TX
I don't personally have one, but from what I have read people are generally happy with them. Don't expect a 100 HP increase but it should definitely be noticeable.
Odimus
Maine
depends...are you running stock air in-take or have the AirDoc mod? I have one on my Ford and use it mostly for towing, back up camera monitor, and clear any codes that might pop up...
Following up on what cbetts said, googling that programmer doesn't list an application for any Hummer but an H1.
I can't believe there is enough "un-tapped" horsepower built into the 3.5/3.7L to bother with a tuner. In fact, considering the electronic demons hiding everywhere inside the H3...it might even be like opening a Pandora's box of trouble codes, with little or not actual performance improvement. I had PCMofNC do some minor tweeking with mine but, I would never expect to see any huge improvements. It does seem to idle better, and has slightly more response right at tip-in...but it feels more like a timing adjustment, and not any sort of true horsepower gain. They firmed-up the shifts as well...stage 2 (head snapper).
In short...You can't polish a turd.
Just drive it. Change the oil. Throw some injector cleaner in once in awhile. And be glad it starts. Expecting any more than this from the 5-cyl. is living in complete denial.
jakesz28
Cabool MO
I have used HP tuners to limit the amount of torque management, raise the idle a little, adjust shift points and firmness, correct the speedometer. But there is little to no real power to be gained.
Would I have bought HP tuners just for the thee H3? NO but since I have been known to play with a few cars and had it sure I made some tweaks.
