Would these rims fit with a Rancho lift?
benlaud87
Maryland
id call them and ask about the hub bore size. it needs to be 4.25" or 108mm I think it is, maybe its 106, either way, they'll know. Do you have a lift, or do you plan on installing a lift? Youre going to want atleast 4.5" backspacing if you are.
and stock wheels are hubcentric, those are not. I personally don't care too much about that though
Cajun_Tiger_Hummer
Lafayette, La
Yup already have the lift on with 35" MTR Kevlar, on stock rims. Looking to move up. Back spacing says 4.75", so as long as i'm not under 4.5" I'm good, correct?
benlaud87
Maryland
4.75 will be more towards the knuckle than 4.5. It will more than likely hit.
The lower the number, the more they protrude from the vehicle.
These are 4" backspacing
poweraidon
georgia
Go with a lower offset my friend has the 4in lift and he's about to get -76 offset rims
Chocflip201
In the Rocky Mountains
Utah
I bet you will just barely scrub the UCA. A 1/4" spacer would fix that, but not legal in all states. You may clear without it. But it will be close.
Cajun_Tiger_Hummer
Lafayette, La
I'm already running 1.75" spacers with my stock rims. I could just use my spacers with the rims. They would stick out an extra 1.5". I could get these rims for $110 apiece and finally run 37" tires
Chocflip201
Utah
Then your scrub radius will be too large and you'll rub the fender and bumper.
