H
H3Ray
Just like the title says ... Lets see whatcha got Fellas !!!!
Here you geaux
is that 35" on a rancho? or that plus something
Also, the THORparts rear bumper comes with two small locating dimples stamped into the back-side of it. Drilling through these dimples will locate the drivers-side D-ring in the exact correct spot, so all you need to do is chuck a 1/2" bit into your drill and have at it.
The spare tire plate kit can be bought here...
http://www.rockhard4x4.com/product_p/rh-4006.htm
It's listed under Jeep parts but, its actually uni-lugged and fits several different wheel bolt patterns...including the GM 6-lug. It has LED lights that shine down onto the plate, and I simply extended the stock plate wiring up behind the sub-woofer cabinet, into the rear hatch door, and out thru the cabin vent. The plate removes in seconds to access the spare. I've been running it for several years...seems to be holding up very well.
The tow-hook on the drivers-side is pretty simple. Drill a couple holes and bolt a stock H3 D-ring to the bumper...then use a piece of chain to secure it to the frame. If just want the "look", you can forego the chain but, I use mine and I have yanked on it extremely hard several times. It might be possible to pull the bumper off the truck, unless you somehow connect the D-ring directly to the frame (like the passengers-side is), so that's the purpose of the chain. It works perfectly and its a simple and effective way to secure it without doing any fabrication or welding to the frame. Also, the THORparts rear bumper comes with two small locating dimples stamped into the back-side of it. Drilling through these dimples will locate the drivers-side D-ring in the exact correct spot, so all you need to do is chuck a 1/2" bit into your drill and have at it.
