Wiring question
Trevon
Rapid City.
I cannot see anything when backing up in my truck if there's no light around. One reverse light is blocked by the tire carrier and the other is so dim it may as well be a candle.
I want to install a RI Dually in the bumper but am not looking forward to rewiring it all to work. Can I just disconnect the reverse lights and extend the wiring to the Dually? Or will I have to rewire with thicker gauge wire and the whole shabang?
Have wired things before just fine, not the greatest at it so I wanted to take the easiest result but do it right.
Thank you
Why not use the power to the reverse lights to be the switched power on a relay? You'd still have your reverse lights and it should be easy to wire. Tap into the reverse circuit for the switch on the lights. While the Dually doesn't use a lot of power, I'd be more comfortable if it had its own power, perhaps from an Add-A-Fuse in the fuse box.
Trevon
Rapid City.
ah, I didn't even think about adding a relay from the reverse circuit.
I am not that great with how to wire things but if I saw a schematic it would be easy enough to figure out. Now, on past vehicles I've had no problem adding a completely standalone circuit with fusible links, but utilizing an empty fuse spot in the fuse block isn't something I have ever done before.
deserth3
Conroe, TX
Which light do you plan on using? The 2 I checked have an amperage draw of 1.45 amps. The current wiring should easily handle this.
Check the fuse size installed OEM in the vehicle for the reverse lights. If it's greater than 5 amp you are fine.
Amperage is additive. 1 light will be 1.45 amp. 2 lights will be 2.9 amps. 3 lights would be 4.35.
Add-a-fuse goes straight into an unused fuse in your fuse block. http://www.amazon.com/Bussmann-BP-HHH-ATM-Add-A-Fuse/dp/B000GKEXK2. Of course you don't have to go this route for power - if you have a better power source, go for it. I bring this up as too often we dump additional wires straight to the battery.
If you're thinking about adding other accessories, consider an item like this. http://www.amazon.com/Blue-Sea-Syst...9&sr=1-2-catcorr&keywords=blue+sea+fuse+panel
I don't know the options in an H1 for adding power, so I could be off target on what you need. Plus with what Desert said above, I could be overthinking this.
In the diagram below, the Green wire would be a tap into the reverse circuit and would go to #86 on the relay. #30 is power source, #87 is to your Dually, #85 is to a ground.
Kyle
Santa Clarita, CA
do you have the towing package? if you do you couldnt you just tap into the trailer wiring and find the power for the trailer reverse lights, that way when you put the car in reverse it turns the rigid on.
Mb30sdl
Hamster that pokes Bears
Raleigh area NC
Kyle is correct, u need to have control voltage to relay from back up circuit and main power from trailer plug. There is a constant +12v to charge trailer batteries( u may need to install fuse in fuse box). RI use 10 or 15 amp fuse.
deserth3
Conroe, TX
Just one single Rigid Industries Dually flush mount defused light.
At 1.45 amps, I'd go with your original plan and extend the wire from the existing light. Just don't leave the old light bulb operating. Either unplug it, cut the wire or remove the bulb.
Mb30sdl
Raleigh area NC
OEM wiring is VERY small gauge, 2 RI light kit comes with 10amp fuse (I can check today in the shop) so OEM wiring may get burned out quickly.
It may be better to extend it from trailer connector, it has MUCH bigger gauge there and u don't have to open up the light.
Kyle
Santa Clarita, CA
plus no switches or anything to worry about!
deserth3
Conroe, TX
According to Autozone the OEM bulb is a Sylvania 1156LL. It's rated working wattage is 26.88 watts. Rated working voltage is 12.8 volts. To figure out he bubs amperage draw at the rated wattage and voltage you an use ohms law. Power=amperage x voltage. So dividing 26.88 watts by 12.8 volts. The amperage draw at the rated voltage is 2.1 amps.
The expected amperage draw determines the size wire a circuit will have. In other words the higher the amperage draw the larger the wire. So it would be safe to say you can safely replace the OEM incandescent bulb with an LED lamp with an amperage draw of 1.45 amps.
I will say once again. Look at your fuse block to determine what the factory fuse rating is.
I think we're discussing some apples and oranges. Adding a full draw onto the OEM wiring (i.e. using the OEM wiring to power an additional lamp) might be too much, even as little as the LEDs draw. My suggestion was to only use the OEM backup wire as the switch wire, which would be a nominal draw and should not overload the fuse or wires. And not switch would be necessary. I would use an new, independent power line for the primary power.
Serge's recommendation is a good one too, to use the trailer wiring, if so equipped. I figure that's standard on an H1 but am not positive.
Adding some LED's will be fine, like with any added load. Keep it within the limits of the fuse and you will be fine. The trailer harness under the H3 has a reverse light wire for reverse lights on a trailer, it is tied into regular wire so half the work is done. So the assumption from the factory is you will at least add 2 additional incandescent bulbs at 25 watts each. That leaves a lot of room for LED's. My 3 - 3 watt LED's that I added draw a combined .7 amp, that is nothing, even since I added LED's inside the stock sockets. I draw far less then what it is capable of.
