High Five H2
- West Texas
Ok, I know I've brought this up before, but I am adding a CB radio pretty soon and I'm looking for a simple, permanent way to do the wiring without being too complicated. I don't want to add an auxiliary fuse box just yet because the CB is the only thing i'm adding right now. I'll probably do that later on.
Anyways, here's what I'm figured out:
There are 3 empty fuse slots in the fuse box under the hood. According to the guide on the under side of the lid, they are unused. I have an alpha, so I think i have every electronic doodad that's available in an H3 (it's not an adventure model, but I couldn't find a fuse for the locker. i think it's fused through the TCCM). The empty spots are hot - I checked them with one of those doohickies that lights up. I don't know what it's called.
I'm thinking that all I need to do is take apart the F box (heh heh), see if there's a wire going from the accessory side of the fuse to the wiring harness, add one if there isn't, add a pin to the harness on the other side, and connect the wire.
I may take the F box apart tonight and see. I'll take some pictures. Any idea where I can get the pins that go in the plugs themselves?
if this works out, then I'll be able to hook up the CB radio and an amplified PA speaker pretty easily. I'll do an aux F box later on down the road.
