Zombie Switch
LoJac963
Surprise, AZ
zombie targeting system second from the right lol
LoJac963
Surprise, AZ
I also recommend the link above, that's where I bought all my switches and bezel. He has a huge selection and can custom make faces if you so please. He is also very quick to reply to emails if you have questions-in my case I was so confused as to which switch I wanted.
Also buy the tool to remove the faces, it is cheap but well worth it. Find the switch and LED colors you want and buy everything. You can always change the faces out if your mods change. I knew eventually I'd have enough lights to warrant all 6 switches. That is why the right 2 switches are just fillers for right now until I add more, then I'll change the faces of those switches.
In an 06 I'd put them ahead of the shifter where in 07 and later they put the little coin pocket. Or if you're going to have 6 switches that might work there too for 07 and up by cutting out and removing the pocket.
My spot didn't work great for me as it doesn't sit quite flush. I may not have cut enough of the metal backing out of the way. Paladine did a great job with his switches in this location.
Peep
Belize
That is where I have my 8" HID light switch. Not very easy to find at night and not the easiest to use when doing difficult driving
