Underwhelmed by H3T backup lights...any bright alternatives?
derian06
Red Rockett
Madison, AL
Plenty of light and I wired it to the reverse lights
How did you splice into your reverse lights?
Chocflip201
In the Rocky Mountains
Utah
start at post #187
http://www.hummer4x4offroad.com/forum/showthread.php?5816-Search-and-Rescue-H3-Alpha-build/page13
the only thing to remember when you pull the console (that requires pulling the seats) is not to turn the car on while the seats are disconnected.... the bcm does NOT like that at all
By pulling the seats, you mean pulling them out of the car? That seems like alot of hassle for some switches if so. I remember pulling up my console to wire my l.e.d. Footwell lights, so i don't think thats the case.
to get the console out, you have to remove the rear, inner bolts on both seats - I don't suppose you have to pull the seats out (you can slide them off the tabs), but it helps... and they're really not that heavy.
But your don't have to pull the whole console to install switches there, open the center console lid and lift up on the seam and all of the snap clips will start to pop loose, out the shifter handle in neutral (set the park brake) and you can get the top half of the center console completely off and you can work the coin slot out of the vehicle. .
