TAPDH3T's SAS
I believe the "truss thingy" is a dealer installed add-on to help stiffen the housing. These were all the rage in the early 70s, and there are probably some guys with bone stock resto rigs that would want one. The truss completes the heavy-duty stock look...for instance:
Its not the parts, although a leaf-spring rig would obviously be cheaper (less parts). The real killer is labor. There is a TON of cutting, chopping, fabrication, welding, grinding, etc. All of that takes time. Shops around here (and I feel the midwest is cheap) charge anywhere from $40 to $70 per hour. You're looking at two-weeks (80 hours) if you totally know what you're doing, and you've done an H3 before. The problem is....very few people have. This "indecision" time is what kills the budget. I promise you...anybody that does an SAS on an H3 will spend way more time than they originally planned for. This is because there is no such thing as a "kit". You will have about a 40% success rate on pretty much every little task. Order. Wait. Receive. Test fit. Send back. Order again. Wait. Test fit. Okay...I can make this work. On to the next problem. And on and on it goes....seemingly forever. The worst part is: Our vehicles have a certain "high-end" reputation. This makes it even harder to take a torch to them.
Myself and a few others have been there. I'll help anybody that wants to give it a go. Its very fab-intensive and custom, even with advice. The first cut is the hardest.
this should be required reading for anyone that is doing any vehicle work that isn't maintenance.
you can't possibly be saying that axle trusses are no longer useful....
That ain't a truss. Its basically a piece of bar-stock bolted to the bottom of the housing. I doubt if it really does much but, back in the day...that was all there was. Resto guys go ape-$hit for vintage parts like this. Just like a Warn 8274...there are much better winches nowadays but, having an 8274 on your old-school 60's rig is just "cool".
8274 is cool until the brake doesn't hold...
