What battery to use?
rsm688
mississippi
Okay guys well the battery that came in my hummer is toast, it won't hold a charge well and it's also a little too big to sit down flush in the battery box. What battery would you guys reccommend for my 06 H3? Should i shell out the extra $$ for an optima battery or just pick up an auto zone one. I've got DVD/Nav, HID headlights, and no other electrical mods so I shouldn't be pulling too much power
Thanks,
Spencer
rsm688
mississippi
Also, does anyone know what gauge the factory power wires are? I was going to ditch the factory terminals for some Stinger terminals but have no clue which ones to order.
Thanks,
Spencer
I got some stinger terminals. One 4/8 awg (neg) and a 4/4/8 awg (pos).
I also have an odyssey 34/78 pc1500dt battery. I love the setup. I have my winch wired to the front terminals. the stinger terminals on top and I have an aux fuse block off the stinger + terminal with a 50amp inline maxi fuse.
derian06
Red Rockett
Madison, AL
X2! Best battery i've ever used.
Big2dabank
Central Florida
Diehard Platinum P4, the P4 is a dual terminal group 34/78. Pretty much the exact same battery as the Odyssey PC1500DT, but much cheaper. $229 at sears.
Diode Dynamics
LED Lighting Experts
St. Louis, MO
You can buy Optima batteries at Sam's and Costco for around $150
Just make sure you buy an AGM battery, they last a lot longer and are considerably more durable
Nick C.
S
SedonaBound
Since you have no winch or need for a deep power draw or special need, I'd stick with the OEM Grp 86 in whatever brand/warranty/cold cranking power best suits your budget.
