Replacing upper control (A) arms and shock
First off I will say this is something that if you are handy, you should be able to tackle. Took about 2 hrs for the drivers side then about 1 hr for the passenger side. Passenger side isn't any easier just figured out how to do it. This first picture is just showing the big screws that can be difficult to take off. I will say this is pretty straight forward just removing some bolts and swapping out parts. You can do this without removing brake lines. 2nd photo is after the fact. Bilsteins look pretty good. Ride is a lot smoother and these are the shocks with the extra 2 inches because I did the torsion bar lift in the front.
cbetts
NERD!!!
Rancho Palos Verdes, CA
Looks great! I recently did the same. I figured that since everything was apart, might as well do the wheel bearings and loew ball joints as well.
I didn't have enough confidence doing it mystlf and had my shop do the heavy lifting though.
Ghostbuster next mods are gonna be front bull bar, nerf bars, winch, and try to figure out how to do the roof marker lights package
I strongly advise against nerf bars.... If you plan to wheel it, which seems like you do since you want a winch, you're gonna catch those damn things on everything. I've had to help pull bent nerf bars off a tire several times. It involved a tow strap and gently pulling on the bar to bend it back into position... nerf bars really are a hindrance off road and provide zero protection... Check out "rock sliders". There's a few options out there for us.
Ghostbuster
Sorry if this is a stupid question... but why do people replace the upper control arm? Do the joints wear out and you have to just replace the whole thing or what?
Hayden
Toyo M/T
Virginia, US
The upper ball joint isnt removable so you have to replace the whole thing instead of just the ball joint. Kinda a pita
