WRB100
- United States
I have read several threads about misfire issues and find that most have certain critical differences and several different solutions. I would like to ask you all what you would do at this point of my issue.
Vehicle: 2006 H3
Engine: 3.5L 5 cylinder
Vehicle miles: 92,000
Occurrence One: Check Engine light appeared and scan tool stated a misfire in cylinder 2.
Steps taken: I changed the original spark plugs making sure to replace with AC Delco Iridium plugs. I also switched around the coil packs between cylinder 1 and cylinder 2.
Occurrence Two: After several hundred miles later the Check Engine light appeared and scan tool stated a "random" misfire. No particular cylinder.
Steps taken: Delivered to GM dealer for check up and they scanned the engine. Reported to me the two occurrences of error codes. Told me they cleaned the throttle body and tested. Nothing more to do.
Occurrence Three: After three weeks away from dealer and about 1000 miles later, I have received another Check Engine light. I have not attached a scanner yet, but can only assume it will be a misfire since it appeared at idle just like the other occurrences. What steps would you take at this point?
Replace cylinder 1 Coil Pack?
Return to dealer?
Or something else?
Frankly, I do not trust this particular dealer. For one, during the duration they had the vehicle they told me they wanted to change the spark plugs because they were original. I promptly told them I changed the plugs already. So, I caught them in a lie. I live in South East Michigan (Metro Detroit area) and would like to possibly get a recommendation of someone local who really knows these engines and will give me an "honest" and educated survey of this engine and issue at hand if that is the consensus to take to a mechanic. Either way, I intend on keeping this vehicle for a while and would like to find a professional that will treat me right.
I appreciate any help any of you have to give and thanks in advance.
WRB100
Vehicle: 2006 H3
Return to dealer?
Or something else?
WRB100
