Hummer H3 Oracle HALO headlight kit
rsm688
mississippi
I have a new in the box set of Oracle HALOs for the H3 headlights. This kit is the White Plasma kit (plasma is the best), I went with white so it would have the look of a nice high end vehicle. I paid $200 shipped for the kit. I've decided not to use it after all as I am going to build some custom headlights with projectors installed in them and all instead. First $100 takes it.
Thanks,
Spencer
rsm688
mississippi
Are they hard to instal?
I wouldn't say it's hard to install. It will take a little time though. Gotta remove the headlight assemblies and remove the lenses to install them. I've got a good writeup on how to do them I can send you (including several tips from Derian)
Spencer
Spencer
Want to post it up or add to Derian thread? More Info the better!
derian06
Red Rockett
Madison, AL
You just run two wires positive (to a switch) and negative *BUT THE NEGATIVES NEED THEIR OWN TERMINALS* this goes unnoticed by many, but if you do not give them each their own negative specific led's will burn out *ONLY ON ORACLE PLASMA'S* but using a dremel to cut open the housing is alot easier than prying it in the oven. It really isn't that bad but it takes time and you need a steady hand
