- Meridian, ID
Sway bar mount broke? You have pics?
I've done sway bar work on several H3s and those mounting bolts commonly snap off. GM uses very soft bolts on these, and I replace them with better versions....with plenty of anti-seize of course.
On the rear...you can usually vise-grip the broken bolt from the underside of the bracket and spin it out the bottom. Unfortunately, the fronts always need drilled out because there is no access to the backside.
I use Spohn discos...nice stuff. They make several lengths and you can cut them to fit....
http://fortmyers.craigslist.org/chl/boa/4979665191.html
heres my version. $20 something bucks at ace hardware.
