06PullUouT
- Kingsland, GA
I have had an ARB air compressor sitting in my garage for the past 4 months so I finally got some time to start the install.
The vehicle: 2006 Hummer H3 (slowly turning it into an overland vehicle)
I chose to put the compressor in the rear door recess.
I started by creating the brackets that will hold the compressor to the door. I used .45 aluminum strips and used my brake to bend the metal.
Time to fit up the brackets.
I used #6 bolts and heavy duty rubber washers to reduce vibrations.
Ran out of time today so I will do all the wiring and painting tomorrow. I plan on running the hose to an onboard 2.5 gal tank mounted under the truck.
-Deryl
-Deryl
