New h3 owner
razortray
I just purchased a 2007 h3 yesterday. It has the 5cyc. I am not familiar with hummer's at all. It is all stock currently plan to lift it and maybe a set of 35s later. First off are there any major issues with this model. Or anything I should keep an eye out for in particular? Thanks for any help in advance
Welcome from up near st. louis... Check the Midwest section. Thats where you can find some H4O outtings to come join in on.
razortray
Thank all of you this may be another dumb question but what does h40 mean?
adventr
I'm just across the border in Tulsa. Interested in running up to Southern Missouri for wheeling this weekend?
Was hoping I'd be able to make that trip, but this weekend just isn't going to work for me...
Going to Moab in early October though, if anyone in this area would like to join.
razortray
If I would have known sooner I would have definitely made the trip. adventr your not to far from me if you ever need anything or make it this way give me a shout. And here's mine.
I'm sure there will be another smorr trip in the fall... If you plan to wheel it, try and find some undercarriage protection and rock sliders. Especially if you stick with 33s for a little bit. Other than that, just normal maintenance things... Wouldn't hurt to change the fluids. Relatively cheap and you can do it yourself... Then just enjoy it and mod as you see fit.
razortray
Yes all stock for now I actually plan on the rancho 4" and 35s-37s I think. I don't do a lot of wheeling. Do a lot of hunting that takes me in some muddy places occasionally. I have changed all the fluids did that the second day actually like to know all that is done. Buying used there's always that uncertainty. I've also ordered a light bar for the bumper not sure if I going to leave the brush Gaurd on just yet
CaddyStrophic
I've had my H3 for a year and a half. I've had to replace the thermostat, radiator, axle seals, coil packs, pcm and a few other things. Hope you have better luck than me!
H3HummerLineX
SoCal, Chatsworth
If you have the I5 stay at or under 35" tires. It will be a pig with 37. My opinion.
You'll have fun with it, it's a good vehicle
