jacobharris84
- Ohio, USA
How do I go about fixing a trashed crossmember bushing? Is there a kit? Do I need to get a completely new crossmember? Please inform me!
I did the one from Scorpworks and it is worth every penny. Solid as can be and I never worry about it anymore.
The scorpworks is the one from Dwayne/Preferred Chassis Fabrication I linked earlier. It is a the whole crossmember, not a bushing kit. It's super easy since all you do is order one, then when you get it, remove your old one (5 bolts), bolt the new one in, and then send your old one back as a core. Nothing special about it, you can do it in your driveway with hand tools.
Even with the OD bushing kit, it's more or less the same, though you then have the fun job of trying to get the old bushing out which probably will involve either a big shop press if you're lucky to have one, or using a torch and burning out the old rubber bushing and getting the bushing sleeve out, depending on how mangled the old one is. Still, it can be done with hand tools in your driveway. It'll just take a lot longer than one would hope, depending on how stubborn the old bushing is.
