Marinmcgreevy
- Mt. Lebanon, PA
I hoping someone can point me in the right direction.
My H3 is making an intermittent sound. Not a good sound. I have not been able to find the source.
What I find:
sound source is in the engine bay. Drivers side.
Sound is not dependent on road speed or engine speed.
sound is being generated by something that is rotating.
Sound does not occur while driving under load
sound only occurs while coasting on level ground.
Sound does not go away if brakes are applied
water pump is not leaking
a/c compressor engaged/not engaged has no influence on the sound
noise sounds metallic but not with a lot of mass associated
cycling through transfer case locked hi lo has no influence
everything under the the hood looks ok. I have not been able to hear the sound while at idle. The truck has to be moving
My wife first detected the sound and when I drove the truck I got the sound. I immediately thought (but did no accuse) that she had run over something. No garbage can lids this time.
My my first thought was water pump or belt idler pulley but the sound is not engine speed dependent. Fan clutch is fine. Then perhaps something associated with the front axles but the sound is not road speed dependent.
The he sound will disappear for 200 miles at a time but will also start and stop during a single drive
i am stumped and do not want to just start replacing things. The sound is loud and I generally do not like to run anything to failure.
Any ideas would be hugely appreciated!
Evan.
What I find:
Evan.
