Rear Differential Cover - What are you using?
Bowser-II
Hagerstown, Maryland
I am looking at replacing my rear differential cover *with something a little stronger than the factory cover*, and want to know what works well?
Of particular interest is any overhang of the cover, have you needed to grind it smooth?
edited to explain why...
1DIRTYH3
Solid diff cover from solid axle...$65
Vdawg1115
Oakland, CA
I use one from ChassisUnlimited. They're a local business. Comes unpainted but really thick and strong
Best4x4
Vidor, TX
I used a G2 Aluminum Diff Cover. It was extremely thick, had fill/drain plugs, and I never had any issues with it.
Bowser-II
Solid is the only way to go, anything more is waste, anything less isn't done right.[/QUOTE]
Eric
Two questions on the Solid, because I did look at those and price is reasonable.
1, does the cover flange hang below housing, creating a catch point for stones?
2, it looks like the fill plug is a little higher than factory, are you doing by volume or by over flow?
Sent from my XT1060 using Tapatalk
Schwarttzy
Rockford IL
There are no catch points with Solid differential covers. You should always go by volume, based off the manual. It's been awhile... and I don't remember the volume off had.
Here's the original pic but it's still going strong nine years later. Of course there aren't many rocks on the way to church each Sunday :giggle:
