Got a squeak after wheeling.
CaddyStrophic
Went wheeling this weekend, hit some pretty good mud and water-crossings.
Aaaaand now I have a. Squeak that is driving me insane. I think it's a belt tensioner or something involving the serpentine.
Anybody have this issue before? The only thing I can think of is to use a soapy paint brush and try to clean behind the belt tensioners and such.
Cowboy
Alameda
Need more information. When do you hear it?
Can't make it through the day? Back up, and get a run at it!
Try some Simple Green, soak the area and wash with low pressure water. Dirt in the moving parts could cause a squeak.
Chris Laun
Los Angeles, CA
I went through a couple huge dirty puddles and a very murky stream while wheeling one time in my 06 h3 and developed a belt squeak on the way home, but I left the truck running when i rinsed it off after getting back to my house, and the squeak went away. So I'm guessing its dirt in the pulleys as well
awalsh
New Jersey
Same thing on mine for a while. WD40 does the trick, belt lube helps for a little bit but not a permanent fix. My belt squeak has gone away but now I have a squeak in my suspension which is driving me more nuts than the belt did.
Does sound like pulleys and not a belt. Remember, squeaking belts is more about pulleys with too much resistance, i.e. failing, vs. a belt issue. A little lubricant in the pulleys, one at a time, might help you find which one(s) are making the noise.
