Anyone ever seen this gear light issue on dash? VIDEO INSIDE
GreatDaneHummer
Chicago
I had a lot of intermittent power issues with my dash when I did not have a proper ground on the battery terminals but if this was the same case it would be your entire gauge cluster not just one section. Poor solder joint etc sounds more in line.
Mea culpa. I believe that you are the most knowledgeable person I know who knows about the specifics of the H3.:woot:
Not anymore! Trying my best to forget.:giggle:
But will tell the OP, the H3's I/P cluster is one of the easiest clusters to replace, and it used to be really cheap, cause it is really cheap.
