Hey everyone. Haven't been around in a while. Hopefully everyone is doing well.
Vehicle:
2008 H3
115,000 Miles
3.7l
Issue:
When I'd drive over 20 mph I start hearing and feeling a thump that cycles in revolutions. As I go faster the sound is more frequent. It seems to be coming from the front. I feel it in my gas pedal and on the passenger side front. It started after having to get on the brakes really hard due to an idiot pulling out right in front of me and almost getting T-boned.
What I've done:
My first though was it must be something with the front passenger side brakes. The wheel was pulled off and the pads, rotors, calipers, and caliper pistons seemed to be in good shape. So then I considered the wheel bearing. The truck got jacked up, and I did the 6 o'clock and 12 o'clock rock to check for vertical play. There was a decent bit. So I went ahead and replaced the wheel bearing and hub assembly. Unfortunately the thump is still here.
Does anyone have any ideas what to start checking and looking for next? Fortunately my grandfather is letting me use his truck until I can fix mine.
Thank you everyone,
Cory
TL;DR Odd thumping past 20mph on the front end. check brakes, they were fine. replaced wheel bearing and hub, thump is still present.
Vehicle:
2008 H3
115,000 Miles
3.7l
Issue:
What I've done:
Thank you everyone,
Cory
