Hummer h2 build ideas
Bmonts h3
Mobile,al
Hey everyone I'm looking at swapping my Jeep Wrangler for a hummer h2 in white with the 6.0 motor. I'm just curious about some of the cool mods you guys have done to yours. I'm wanting to do a 6 inch fabtech lift with 18 inch cleaver rims in black and 38 inch mudgrapplers any advice would be greatly appreciated. I will upload a photo of the hummer that I'm wanting to make the one I hopefully get look like.
Bmonts h3
Mobile,al
Yeah I see that they usually beef the front end up I don't plan on going off-roading much until I get the front end beefed up lol those are good ideas on the electrical system I wonder how much that would run?
Bmonts h3
Mobile,al
Swapped my Jeep for a 2006 hummer h2 luxury today it has 37 inch tires on it now do you all think I should put 40s and 20 inch rims on it the the 37s look very small I'm wanting nitto mudgrapplers and 20 inch cleaver rims any advice would be very much appreciated.
GreatDaneHummer
Chicago
Keep it looking tough don't go with the girly wheels you cry when they get scratched. Put some Spyderlock Beadlocks on there and some big 37" Pitbull Rockers with a good 4" lift. Make it awesome. REMOVE THE CHROME**
Bmonts h3
Mobile,al
I think it's got a 6 inch lift on it now and I'm definitely going to black all the chrome out can't stand chrome lol thanks for the ideas GreatDaneHummer!
Big2dabank
Central Florida
I am running 38s with no lift. As far as mods, I run front and rear lockers and 4.56 gears, Dynatech Headers, DIY on-board air system, modded the rock rails to bump them out 2", Kryptonite centerline and tie-rods, and many more I am forgetting about over the years.
Bmonts h3
Mobile,al
That's a really nice rig you have there big2dabank! Do you get lots of rub with the 38s and how do you like the 4.56 gears better than the 4.10 's for 38's???
LoJac963
Surprise, AZ
20" wheels would be a major NO from me but it's your rig-do whatever you want to it. Huge sidewalls serve a purpose when offroading, 20s are pretty much worthless once you leave the nice paved roads.
Big2dabank
Central Florida
Very slight rub at full lock, which is no more rubbing than when I had 37s. The wheels are 18" x 9" and the 38s are 38x13.5s, which IMO are the perfect size on an H2. I do have a 2" coil spacer in the rear and torsion keys up front, so that also helps. As far as the gearing, I probably should have went to 4.88s, but the 4.56 do fine, way better than 4:10s, which was very sluggish.
Bmonts h3
Mobile,al
Nice ride citiboy I love the blacked out look have my h3 that way!! And thanks for the good info Big2dabank I'll probably go with the 4.88s with 38 or 40s or would you say I should go with 5.10 gears with the 40s????
High Five H2
West Texas
A few people have floated the idea of doing a solid axle swap using the AAM 925 axle from 03+ dodge rams 2500 trucks. It's basically the solid axle version of the H2's front axle. The electronics are the same.
Mb30sdl
Hamster that pokes Bears
Raleigh area NC
Thats a BS I am running 20x12s with 38/15.5 for years now ( sometimes with trailer on same wheels)never had any issues on or off road. They do look much better vs. SMALL 18s. And I do off-road more that 80% of people on this forum.
Big2dabank
Central Florida
I think 4.56s are perfect for 37s and 4.88s are perfect for 38s. I am still running 4.56s with 38s and its a bit sluggish, but still plenty of power when I need it. I still tow occasionally an am not quite ready to go to 4.88s. If you plan on going to 40s I would go straight to 5.13s, possibly even 5.38s if you don't tow anything.
Here are a couple of quick gear ratio calculations for you.
For stock tires and gears;
(4.10 x 60mph x 336)/ 33.6 inches = 2460 rpm 3rd gear
2460 x 0.696 (overdrive) = 1712 rpm
For 37s and 4.56
(4.56 x 60 mph x 336)/ 37 inches = 2485 rpm 3rd gear
2485 x 0.696 (overdrive) = 1729 rpm
For 38s and 4.88s
(4.88 x 60 mph x 336)/ 38 inches = 2589 rpm 3rd gear
2589 X 0.696 (overdrive) = 1802 rpm
For 40s and 4.88s (I personally think this will feel bit sluggish because of the added weight of the 40s)
(4.88 x 60 mph x 336)/ 40 inches = 2460 rpm 3rd gear
2460 X 0.696 (overdrive) = 1712 rpm
For 40s with 5.13s
(5.13 x 60 mph x 336)/ 40 inches = 2586 rpm 3rd gear
2586 x 0.696 (overdrive) = 1800 rpm
For 40s with 5.38s
(5.38 x 60 mph x 336)/ 40 inches = 2711 rpm 3rd gear
2711 x 0.696 (overdrive) = 1887 rpm
