- Tardville
Thread Hi-jack!...
I'm sure this is different from Dana60's but, good info all the same if you are considering a SAS. This is a custom passenger-drop hi-pinion D44 housing in an H3T. Coil sprung, 3-link suspension. Steering is typical cross-over, low-steer using a p.s. GM/Jeep flat-top knuckle. The box is a Nissan Delphi unit (from an Xterra), rebuilt & ported by WTO for ram assist, custom pitman arm. It uses a stock GM p.s. pump. Frame rails have been plated with 1/4" steel and there are sleeves and an inboard plate where the box attaches. There are two ways to connect to the steering column to this box. You can either grind flats on the input shaft of the box to accept a stock Hummer intermediate shaft...or build a new shaft with the correctly splined u-joint to fit the Nissan shaft (without grinding). Since this truck has a body lift...I'm leaning toward the new shaft, because I can build it to account for the extra length that the body lift requires.
Now if I could just get Borgeson to return my emails! Bueller? Bueller? Anyone?...
