Hi everyone, thinking about buying another H3 (and probably will ). We had an 07 some time ago and the one under consideration now is an 06 base model with a few suspension issues. Under acceleration it has a bad vibration/shake as if it has square tires! There is also a clunk under the floor when turning. I think it is probably the notorious diff. bushing which does appear to have alot of play in it. My concern is replacing just the crossmember bushing may not cure the entire issue, I may need to do all 3. The other 2 however, don't appear to be loose. I know this is a fairly vague description as I haven't had alot of seat time in it, but to the several here that have had the same or similar issue and replaced their bushings, what was/were the symptom/symptoms you were experiencing and which bushings cured the symptom?
Also, the OEM headlights and foglights have the typical "frosted" covers from sunlight. I have seen factory replacements on ebay that aren't very expensive but if I'm replacing them anyway, why not make them better! Is there an aftermarket supplier for quality housings and bulbs that anyone can recommend?
Thank you for any suggestions!
