Wheel Spacers installed - Pics
classic87
Wichita
Got the 2" spacers installed last night... I love the wider stance and the ride itself has improved.
Not sure what is next... hmmm.
lowtrac
Georgia
That does look good. I've got 18" Rockstars and the back spacing make them stick out about that far.
grod98
Ny
Ouch, haven't seen that style of spacer mounting before. 1" spacer using bolts instead of studs?
They are actually cut studs with nuts on them. It's a 3/4 spacer it pulled right threw
Washington
3/4 spacer ain't that big by the time you recess the mounting holes. I would think a 2 inch would be much more robust with enough meat to keep it together. Do you know off hand what grade aluminum was used on you 3/4" spacers?
im in the market for a set myself, I like my wheels but I have too much rub on the sway bar that needs fixed.
