awalsh
- New Jersey
I wouldn't post this unless I truly had no idea what this noise is but here we go..
Trucks been fine (no noises, etc) for a while after I did a new rear u joint in January..
Spilled water on my headunit and messed it up a bit so sometimes I don't have music at all
Because of this, the other day I noticed this weird popping/clunking noise whenever I decelerate almost to a stop - braking or just coasting to a stop
Sounded like it was coming from under my feet so sure enough I realized one of my skid plates (one under the dif) had a broken bolt and was dangling so I took the whole thing off
Thought I solved the problem but sure enough same noise came back today
It's hard to really pin point since I can only hear it when I'm decelerating
So what I do know to rule some things out.. It's not the u joints all are in decent shape, not the crossmember bushing, not a skid plate or heat shield
What it could be.. Maybe something in the rear brakes but not too familiar with brake noises, or maybe a hub? Also my front shocks are blown and squeak but I don't think that decelerating would cause for a weird clunking noise
I'll post a video if that helps but I just wanna fix this damn thing it's making me go nuts
