Alpha X
- The Motor City
Make your Trans Fluid Temp display in a 2010 H3T Alpha, using CANSF. The 2010 has the LH9 5.3L V8, 2009 has the LH8. If you go by what ScanGauge lists on their website, it won't work in an Alpha because I believe the code for the I-5. You might get it to read "32". That's not correct. Use the following data code. I also added Engine Oil Temperature and Engine Oil Pressure. Data codes below. If you have an UltraGauge, I've read you can translate these codes to work for you. This should work for H3 Alphas as well. I believe this also works for the Colorado & Canyon with V8 of same years.
Trans Fluid Temp - 2010 H3 & H3T Alpha
TXD: 07E2221940
RXF: 046205190640
RXD: 3008
MTH: 00090005FFD8
Trans Fluid Temp - 2008-2009 H3 & H3T Alpha (I found this in another thread)
TXD: 07E222194001 (this didn't work for me because of the last two digits 01)
RXF: 046205190640
RXD: 3008
MTH: 00090005FFD8
Engine Oil Pressure
TXD: 07E0221470 (2010 Alpha)
TXD: 07E022147001 (2008/2009 Alpha)
RXF: 046205140670
RXD: 3008
MTH: 001D00320000
NAM: EOP
TXD: 07E0221154 (2010 Alpha)
TXD: 07E022115401 (2008/2009 Alpha)
RXF: 046205110654
RXD: 3008
MTH: 00090005FFD8
NAM: EOT
TXD: 07E2221940
RXF: 046205190640
RXD: 3008
MTH: 00090005FFD8
RXF: 046205190640
RXD: 3008
MTH: 00090005FFD8
Engine Oil Pressure
RXF: 046205140670
RXD: 3008
MTH: 001D00320000
NAM: EOP
RXF: 046205110654
RXD: 3008
MTH: 00090005FFD8
NAM: EOT
