- WI
Just wanted to report that I finally bit the bullet and bought a new $120 sunroof gasket (or Weatherstrip). There's quite a bit of difference in 'springiness' and firmness between the old and new. Where it wasn't sealing well at the corners before, now it is. If you have an original sunroof gasket, you might consider replacing it just to keep water out. Of course I know there are drain tubes (my ends are clean), but if the vehicle were on a slight angle, it would leak during a big downpour ...the water wasn't able to drain out if the tubes fast enough. I try to park level, but now it doesn't come in ..in the first place.
An interesting note: I was surprised there was quite a bit of dirt and debris which had worked its way between the grooves around the glass which retain the gasket in place. That could possibly be another leak point (past the dirt). I used a toothbrush and soapy water to clean it off before installing the new gasket.
Took about 5 days with my carpet in the sun (upside down) to dry that darn foam backing. That foam is a wonderful water-holding sponge. I want to make sure there aren't any more leaks before putting the carpeting back in. The moisture had caused a small rust hole I needed to fix.
