T-Case does not like shifting to low range
LagunaH1
Idaho
Hi guys,
I was out playing a little bit on North Main Divide road today and had a little bit of difficulty getting the T-Case to stay in low range.
Here's what happened:
1: Stopped, put the transmission in N and shifted the tcase to low range and saw the green tcase lock light come on.
2: When I put the transmission in D, the tcase light went out and the tcase shifter popped into neutral
3: I shut down the engine and shifted the tcase back into low
4: started up and drove off and everything was normal.
5: Coming off the trail, I did a semi tight turn and the T-case light would flicker on and off
In the past I have had a little bit of trouble getting the truck into low range, but once there it always stayed there.
What do you all think?
LagunaH1
Idaho
Update: So far I am finding through research that it could be a matter of the shifter linkage needing an adjustment
I am shocked no one has responded here yet. BUMP for you. I am sure Tustin can figure it out easy if it comes down to that.
Ron B
Los Angeles
I don't know alot about tcases except you shift them like you hate them and if they pop out of gear it could be a part inside the tcase that is worn...a cheap part, but you have to open the tcase to replace it. I seem to remember them being the little plastic shifting fork thingamabobbers? David...Kurt...help!
They are a bit cantankerous. I sometimes have trouble getting them to pop into low, sometimes the will pop out a few times and the light can be on or off and doesn't always correspond to what is going on with the t-case. It has never indicated a real issue with the t-case. Not saying you don't have an issue but try it several times over the next few days and see if you get the same result.
LagunaH1
Idaho
:) Sounds about right. For now it's something I'll keep a closer eye on and see if it's something I can consistently reproduce. Last time in Moab, I had the same thing happening once or twice but once it was in low range real good, it worked just fine as always. -After all this is a 14 year old vehicle so I'd say it's entitled to have a few personality disorders
And with Dave's recommendation you now have an extra excuse to drive it around over the next few days.
LagunaH1
Idaho
Indeed.... diagnostics..... important....
hummech
huntington beach ca.
i have seen some that needed the linkage adjusted and some that have had warn trans mounts. i will have those alignment shims later this week so next week i can look it over for you if you have time to run it by.
