General Questions on current and future products
atvspeed4
massachusetts
Hi guys,
Sorry for the delay in setting up our sponsor section. We have been really busy working on several of our builds, getting ready for my wedding, buying several pieces of real estate and designing some new products. Cant wait until the winter for things to slow down! I will create a different thread for each of our products with descriptions and information on how or why we came up with a certain design. I will also put together a build thread for some of our H3s we have been working on.
Please feel free to use this thread if you have any general questions for us or have any requests for new products.
Thanks for your patience!
atvspeed4
massachusetts
When do you think the differential kit will be available and can you help me with the wiring side of an ‘09 H3T V8 swap?
The final version of the Dana 50 front diff upgrade has been completed and we have been enjoying for about 6 months now. BUT...the reason we have not started selling is that at full suspension compression the inner CV boot on the much larger cv shafts lightly rubs the cross piece of the lower control arm. We strive to have 100% perfection with our kits and until we find a different cv shaft that does not have boot rub at full compression we did not want to go to market.
SlcHummer
Salt Lake City, UT
Does the Dana 50 diff upgrade provide any lift, not including ability for larger tires, and any idea on approximate price range? Also in for pics!
Gpcalero
SW Florida
Hi guys,
So one of the projects that I know you guys are working on is the 6L90 swap kits. I'm the guy that has been religiously following up with you guys on Instagram every 3 months asking for updates lmao. :giggle:
I noticed that you guys haven't started a different thread for this project and I think that if you're asking for requests on new products/build threads then this would be something that I would like to see.
So... any updates on the 6L90 swap kits?? :)
atvspeed4
massachusetts
The 6l90 swap is definitely not for everyone as the only transfer case you can use is a modified np241 (which we used). I believe an atlas might be too narrow and driveshaft would hit the larger bell housing but not 100% on that.
The 6l80 is what we are using on our next full build but the roadblock has been the cost of the transfer case adapter we had made out of aluminum $$$$. The other issue is the company that was going to make us a new input shaft for the non adventure transfer case wants us to order a large run now and we really want to test a prototype first to make sure they get the tolerances right. That leaves us with just recutting the factory 32 spline to 27 spline which we had done but not sure of it's strength behind a 6.2L and towing. It has only been done behind a stock 5.3 and haven't heard long term reviews
Gpcalero
SW Florida
Oh wow. The 6L80 would be the item of interest then for sure.
Question, are the non-adventure and adventure transfer case input shafts different? :huh:
Iwillnc
I may have to add an H3 Alpha to my fleet if you guys are investing this much into the platform.
Gpcalero
SW Florida
Well, I can be the guinea pig for strength testing on the re-splined shafts if you need, as I already have a built 6.2 LS3 sitting in my garage and waiting for the swap into my Alpha Adventure T.
Even if they are re-splined, couldn't you still have it heat treated to restore the depth of the treating in the material after cutting? Or would that not be cost effective?
