Torque App Transmission Temp I5 3.7L
ericemir
US
Hi everyone, been reading a ton on the tran temp code but I see tons of threads on the alpha H3.
I have a 09 H3 I5 3.7L and the GM method 1 reads 32° all the time and doesn't change.
Is this because I torque configured incorrectly?
Sent from my LM-V600 using Tapatalk
Same transmission for the 3.7 and the V8 so the codes should work for either. My Ultragauge has been used between my old 3.7 and my current Alpha and I didn't have to do anything different between the two, both reported the trans temperature ok.
Check this
ericemir
US
Yea that looks like exactly what I have. It only reads 32.
ericemir
US
Deciphering the txd code I used
07E2 as the header
221940 for the obd code
Also tried 22194001 and 2219401
Resulted in either nothing or the same 32°
Alpha X
The Motor City
After you made the change, did you try turning off the vehicle, then restart? This might be necessary to let the communication restart and read new code.
4Lo-Tank
Somewhere in the world
If your torque app is figured correctly, its your bluetooth adapter. I used to have the same problem because i bought a cheap adapter off amazon. For some reason certain signals dont work correctly. I bought a new one for like 50 instead of 10 and it worked fine
ericemir
US
What's a good brand scanner prefer bluetooth
