Just in time for the cooler morning drives to work this fall….
06’ H3. AC works fine. System blows air fine and increases and decreases as it should when turned up and down. System switches between floor, dash, and window as it should.
I noticed about a week ago when I drove to work the AC was still on from the night before and was freezing me out because it was around 50 degrees outside. I turned the AC off by hitting the button and cranked the dial to heat. After about a mile of driving I realized it wasn’t getting any warmer. Hit the AC button on and off a couple times and cranked the dial from hot to cold to hot again and it finally kicked on.
Today as I was driving to work it was cold again. Did the crank back and forth and nothing. AC button on and off, nothing. Never got it to actually blow hot air again.
Thermostat was replaced in 2015 and seems to be running as normal. Running temp is where it should be. Both heater hoses in the engine bay are hot to the touch. Again, AC works fine and blows cold.
I did the actuator calibration procedure I found I online. Listened to it as it went through all the changes. But it’s still just blowing cold.
I’m assuming it’s a bad actuator. Any thoughts? And is this a job I can do myself? What else should I test to ensure I have the right culprit?
