- Scottsdale
Okay, for Moab and other trails I want to make sure the radios are set up ahead of time so we don't have to pull out manuals when airing down just to figure out how to use the radios. Here's what I'm thinking
If it gets busy on that frequency with others not in our group, we should have available a preprogrammed or predesignated "privacy" channel, aka CTCSS. These appears to be a PITA solution because it's not standardized between manufacturers. Here's my thought:
So my radio geek friends, please share your thoughts on this, correct my thinking as needed and make suggestions to make communication on the trails easier. Please note that the H4O Radio Czar, aka LagunaH1, has been nominated to help everyone get onto the right channel as needed.
- 22 (462.7250 mHz) which will also work with FRS and Ham
- If we determine 22 is too busy, we'll switch while on the trail
- Enable CTCSS/Privacy/sub codes or whatever it's called on your radio
- Choose "2" or whatever corresponds to 71.9hz on your radio
