zenoreilly
- Illinois
I thought I was safe.
I thought I had made an end-run around GM's wannabe-antitheft trash fire by replacing the relays and the ignition switch. No PCM coding/tune, no clipped wires or magical fairy-dust; just cry once and replace the parts. I thought I was set for another 100k miles (or however long it takes me to afford an LM2 Duramax and figure out how to get it installed). Just do the Konami-Key-Relearn and I'm set.
HA HA HA no. Seems the Security Dept. got wind of my cleverness, because the light won't turn off while doing the 3x10 relearn process. At all, ever. I put a trickle-charger on the battery and left the key turned on for over an hour, that light doesn't turn off until I take the key out. Just time it for 11 minutes each time, then? Nope. The instructions you find everywhere say "10 minutes or when the light goes out", implying if the light goes out before 10 minutes are up you don't have to wait, but even if it's "whichever comes first" it doesn't work; try to start it and Blinky-Lock say no.
Put the old switch back in, no such problem...except then I'm back to odd delays in starting/random Security Light surprises while driving. This is the 2nd switch after returning the first one thinking that was the problem (and AutoZone is only 2 miles away). New starter and powertrain relays. Battery is fine, terminals are too, but they won't be if I have to keep disconnecting the battery for this and that. What do?
