crank
The Master Blaster!
- Victoria, TX
I have a simple yet perplexing problem for you all.
The driverside door lock knob (you know the black pull up knob on the door top) is broken. This is the older version that looks like an hour glass and the top snapped off. I bought a couple of those and I want to replace them. The broken knob was on real tight and I tried to unscrew it off but all it does is turn real hard. I thought the rod was spinning but its not. I can spend all day twisting it and it will not come off. I even pull upwards while spinning with zero luck. It stays at the same spot.
This sounds like it would be a no brainer. Does anyone know whay this is happening? Any thoughts on how to get that off?
