Griff22usmc
Needs a sponsor
- Wilmington NC
Ok guys need some help. I decided to replace both pads front and back. I am at 92000 and still had 10% left on stock, amazing. Once I got the hang of it, it was probably one of the easiest things I have done on the 3. took me longer to take off the tire and put it back on.
Problem is, I went gung Ho and started unbolting everything on the first one before I realized what to do. I undid the bolts holding the calipers together on the front brake. about a pint of brake fluid leaked out. Immediatly I rebolted it back together and no leaks, everything is good. I finished the pad replacment and went for a test drive. I now have alot of play and gummyness in the pedal. I can pump the brakes 4-5 times and they stiff up. I checked the reservoir and it is halfway between full and min. I have tryed pumping with lid on and off, but I still get the horrible play on the test drive. To the point it takes me 5 seconds to stop at 5 MPH. Im lost right now and have the wife picking me up a botle of fluid on the way home. ANy ideas on what it could be though? Air in the line or just the reservoir not showing the fluid defiency? Thanks for the help.
