I bought the super sparkz mod for $35 and it came with 5 beryllium copper tubes. These tubes replace the springs in the coils packs. This mod took about 30 minutes to do, and you have to remove your airdoc, or intake box to get the coil packs. Once you remove the coil packs from the block, you need to remove the plastic sleeve and use a screw driver to poke out the spring. then you attach the new tube to the coil pack and slide the sleeve back on. Then re install the coil pack and do this for all 5. Before I did this mod, my truck use to run a little rough and the engine would shake. Now since installed them, my truck runs extremely smooth and has a little bit more responsive. I haven't tried it yet at speeds 50+ but I will tonight. I would definitely recommend this mod, it is cheap and inexpensive, and easy to install, and it made my truck very smooth, and it has a little more response to it. Also the truck now runs at lower rpms, I will post back again tonight to say how it runs at higher speeds.
I ordered them from here http://www.355nation.net/forum/supe...ring-delete-upgrade-prices-ordering-info.html
Here is a comparison from the stock springs to the new super sparkz
here is the new super sparkz in the coil pack
