Rear locker for 09 3.7L h3 non adventure.
davidh3
N/A
I wanna buy a eaton rear e locker for my h3.
I want to know which one fits my 09 h3.
and whats the cost for installing at a shop?
I know I dont have tools and a garage to do that.
I have no idea about this but buying it. any suggestion is appreciated.
Thx. :)
A lot of us got good deals off of ebay with iwerearendsonly. I searched for the rear locker on their site and had no luck...
WarMongur
Ladera Ranch, CA
Thx. :)
Mine was around $430 to install, which is on the low side. I got quotes up to $1100. Gotta shop around and choose a shop you trust or that has some good rep.
davidh3
N/A
$1100 is a rip off!!!!!!!!!!!!!!!!!!!! :shame:$430 seems still expensive.
I might go to Pepboys.
Shim kit may be necessary as well. Runs about $80 from GM. I would recommend going to a 4x4 shop or driveline specialist vs. Pepboys.
I agree 100%. May be cheaper initially but if they mess up and your do damage to the rear end then you will end up paying more in the long run.
I got a locker from MaxPF, installed, for dirt cheap. But "dirt cheap" then has the add-ons of the $80 shims, $20 bearings, $26 races, $45 gear oil, $20 axle seals and $25 wiring. Installation is a whole 'nuther issue. MaxPF probably spent at least 3 hours under the truck installing the locker. I spent at least one hour on wiring. That would explain why it took me nearly five years to get a locker as I don't think you will generally get a new one purchased and installed for under $1000-$1100.
alex is right davidh3...its a lot of work. I installed my own too. It took a good amount of time, longer then 3 hours for me. MaxPF has more experience then I do. I broke it into 2 installs, one was the locker install and one was wiring...I actually ran the locker without being wired in for about 3 weeks
Shims can also be a PITA because if you don't get the right shim the first round then you must try another shim.
Reloader
Montana a free state
I got my e-locker right from my dealer. The part number on the box is #25958396, I checked it today at work. I paid $550 for the unit, $90 for the different size carrier bearings , $15 for axle seals and $20 for syn lube. I found a set of super shims in my tool box left over from a previous diff job. Those shims are great. You just build a stack of shims the thickness needed to set backlash. I built a case spreader to facilitate removing and installing the diff assembly. Why I didnt make up one of those years ago I dont know. It sure makes it easier. For wiring I just used a lighting relay with a safety switch on the lower left IP controlled by the ing switch. I put a red led in the dash next to the 4x4 controlls to indicate diff locked.
